2002 Hardtop removal issue | Ford Thunderbird club group 1955-2005 T-Bird models
J
1
Hello I went to remove the hardtop, for the first time, and the drivers side rear latch will not come all the way free. The latching mechanism is pushed all the way to the rear of the car and the top pops up to get my fingers underneath but it will not pull up and pop off. Front torques are unscrewed and rear passenger side pulls free/ Am I missing something or what is the process to remedy this situation. Thank you for your time. JohnG
Is it the seal? Some users in the past have suggested letting the hard sit in the sun to warm up the seals and spray the seal with silicone spray to prevent reoccurrance.
Problem solved I found a post on here making reference to the possibility of the hardtop pin getting bent. So I decided to take a long screwdriver and manually tweek the post and it popped right out. It doesn't look bent but could be slightly out of alignment. Thanks JohnG
Long time owner here - just reattached the hardtop - suggestions —work the stubborn lever back/ forth several times to obtain full extension- then do a two person shake / wiggle and pull up vigorously. The horizontal projections from the vertical pin need to be aligned with the pattern in the receiving receptacle- likely being stubborn four to inactivity.
