Alright guys, since there does not seem to be much info on our stereos here's a tread to log all my aftermarket stereo work I am doing. So far I installed the Alpine head unit. This unit gave me the bluetooth functionality but I think the audio sounded like crap so I decided to put 4 Infinity 6x8's (2 front and 2 back). These improved the sound quite a bit but being one of those dumb guys that is never happy I have decided to take the car apart and install amps and subs. The factory subs are just not that great!
I will say the 6x8 speakers are a good drop in alternative. The Infinity has a few mounting options and on the front door I had to bend a tab on the flange. Nothing bad I did it by hand. The front speakers have a nice "baffle" that remains in place even when you remove the crappy factory enclosure so I will just run a wire from there to the amp in the trunk. This is probable the part that worries me the most as running wires through the rubber loom on the door is a PITA...
I am going to build about a 1/4" spacer on the rear housings to allow their use with my speakers as my speakers are a bit too deep. In order to do that I am going to switch the mount of the housing from the front to the back of the metal wall they are factory mounted to as there is not much space in there for another 1/4" to stick out.
Next, I am pulling the factory subs and going to try to stick 8" subs in there with wires going to an amp in the trunk... The factory housings seem nice ang big enough. May need some type of adapter to fit an 8" and may be some reinforcement of the plastic. We will see. Below are some pics of the progress....
First, I am tackling the rears. I took a 1/4" piece of MDF and glued it to the OEM plastic housings after gutting the crappy factory speakers. The spacer is needed since the new speakers are a bit deeper. BTW, the plastic front plate is held in place by screws from the back hidden in the foam gasket. After prying at it for a while, I figured this out. Also, there is a flange on the front of the housing that I ground down with 80 grit and final sanded with 150 grit.
Here are the rear pics:
