2002 2003 2004 2005 Thunderbird Upgraded Flip Remote Key Fob 315MHz | Ford Thunderbird club group 1955-2005 T-Bird models
Forum Moderator
Staff member
1,228
Our 2005 came with only 1 key, so we must have the dealer program a new key. Will they program a key I didn't get from them? Do these key fob combos from Amazon actually work? Trying to reduce the number of fobs we carry. We have an old garage door opener which requires it's own fob, then there's the gym fob, and the car fob...
The dealer will have no problem cutting and programming the flip key?
Will they program a key I didn't get from them? The dealer will have no problem cutting and programming the flip key?
This a question to ask your locksmith or dealership. Mine Did.
Read the product reviews. I've bought them online and had them programmed. FYI most cars require two keys to program the key chip yourself, since you only have one key you have to have someone with the special equipment do it. The actual keyless entry part is easy to program yourself.
I bought one of the recommend flip keys and the local locksmith, who does replacements for the Ford dealer, successfully cut it and programmed it to the car. Now, however, She says it is too fat and takes up too much space in her purse. I thought I'd replace it with the key that has the fob as its head. If I have one original key and one replacement key, will I be able to program this third key, myself. Or, do I still need two original keys to accomplish that?
Thanks
Thanks
to program a third key you need two different keys to do it yourself they do not have to be original.
My key Fobs do not work on my 2002 T bird. I replaced the batteries, reprogramed them still do not work.Can anyone help me wikth this problem,
Not possible to reprogram the key fob successfully and then they don't work. Note step #7 which confirms this.
First, you must have ALL remote entry transmitters (maximum of four) available before beginning this procedure. To reprogram the remote entry transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 2 (OFF) position to 4 (RUN). [NOTE: Position 1 is fully counterclockwise (key removal), and Position 5 is fully clockwise, or the IGNITION position]
4. Cycle, eight times, rapidly (within 10 seconds) between the 2 (OFF) position and 4 (RUN) position. [NOTE: The eighth turn must end in the 4 (RUN) position.]
5. The doors will lock, then unlock, to confirm that the programming mode has been activated.
6. Within 20 seconds, press any button on the remote entry transmitter. [NOTE: If more than 20 seconds have passed you will need to start the procedure over again.]
7. The doors will lock, then unlock, to confirm that this remote entry transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 2 (OFF) position after you have finished programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming mode has been exited.
And, here is the procedure for programming your PATS Keys:
1. Insert an existing key into the ignition cylinder. [Requires two existing working keys]
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within 5 seconds, insert the second existing key and turn it to ON (RUN) then back to OFF.
4. Insert the new key before ten seconds have elapsed, and turn it to ON (RUN). Leave it on for one second and turn back to OFF.
5. The security light will light up for three seconds to indicate that the new key has been successfully programmed."
One of my T Birds the key fob did not work, except only the trunk open button worked. I purchased two new
key fobs and programed them both, they work perfectly. The programing instructions above worked first time.
Does anyone know how to program a key fob? I turned on 8 times, off 7, when I heard noise, I hit button on new fob. Did not work. And yes door was unlocked.
Lost my car keys last month. Does the 04 Bird need to be programmed or just the key cut? Thanks!
The key is electronic it needs to be programmed. The fob is very inexpensive to replace. But the fob also needs to be programmed. See YouTube for easy instructions on programming fob. But the car will be programmed to the fob not the fob to the car. What that means is old fob will no longer work once new fob is programmed.
Or inherit money and go to the dealer!
Help I need to know the best place to get keys and fob. Can a person program them themselves.
when I replace the fob, because it broke, the old one still worked, just order a new case for it for 7 bucks. and it worked alongside the new ones I got from Amazon. The car programs the fob, not vice versa
