1969 Ford Thunderbird complete overhaul | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter OneAmongOthers
OneAmongOthers
OneAmongOthers
157
Soo for the past couple weeks I have been gathering parts and assembling everything and it's finally the point I am going to be completely be overhauling the entire suspension, brakes and exhaust. So far everything is off and going out to be cleaned and painted before reassembly.
Okay got some work done! New suspension on the driver side is almost all on! Just have to reconnect the strut tension rod, sway bar and tie rods. Brakes still need to go on as well.
Very nice. I have rebuilt my 429 and had a ex coworker who use to be a transmission rebuilder for 14 years before coming to the power plant. I have notice going over bumps and rough roads I have this rattling noise in my front end. Whatever it is does not effect alignment or steering just annoying hearing it. Where did you get your parts from? Appreciate any info. Thanks.
Finished up on the front after completely rebuilding the suspension, brakes and some new exhaust manifolds. Broke off a bolt on the head however. One of the bolts was stubborn and didn't come out. I got new brake lines from classic tube. they were about 80% correct. Some of them were not the right bends or just too long.
IMG_0213.JPG IMG_0214.JPG IMG_0215.JPG IMG_0216.JPG IMG_0217.JPG IMG_0219.JPG IMG_0222.JPG IMG_0223.JPG IMG_0231.JPG IMG_0232.JPG
Started now working on the rear by taking everything off and I am going to sand and paint all the rough spots. Good parts is no real rot under the car. Just mainly surface. Fuel tank was hit apparently then repatched, but to hell with that! Rock auto still had a replacement fuel tank so I ordered it. Axle is being taken out to be sandblasted, and then I am going to apply POR 15 when I get it back. Also going to replace the gasket on the carrier cover as its leaking. Will probably also do the outer axle seals, bearing and such as well. Oh and also completely redo the rear brakes.
IMG_0233.JPG IMG_0234.JPG IMG_0235.JPG IMG_0236.JPG IMG_0238.JPG IMG_0241.JPG IMG_0242.JPG IMG_0243.JPG IMG_0244.JPG IMG_0245.JPG
There was some rot on the frame where it loops over the axle. I cut it back all the way to clean metal, grinded off the rust and then got some flat stock about 12g steel plates and welded in to re-support it. Not the best welder, but I think I did a decent enough job. Just need to do a little more grinding on the welds to make them smooth before repainting it all. I picked up some Eastwood Rust converter, their internal frame coating, a enamel outer coating and some undercoating to go on over top. Also the fuel filler neck is damaged as some of it has corroded leaving holes. Fortunately there is a radiator repair service in my area and they said they can fix it all up good as new so off it goes to them. Afterwards its back together then off to an exhaust specialist for custom new stainless steel exhaust and some nice Flowmaster Super 40 mufflers. Then finally new wheels, tire and alignment.
IMG_0246.JPG IMG_0247.JPG IMG_0248.JPG IMG_0252.JPG IMG_0253.JPG IMG_0254.JPG IMG_0260.JPG IMG_0261.JPG IMG_0262.JPG
Putting a lot of work into it but well worth it. Especially when you get it all done you are cruising and people are giving you the thumbs up. As for the welding looks good enough for what we do for a living( as we use to say at the power plant).
Just got my axle back after sand blasting! So what do I put on it now? I still need to pull it apart and replace some seals, but what to paint it with?
Good question. POR15 may be too good, in other words it may too thick and permanently seal in your drain plugs and fasteners. I's start with a primer right away and then take your time to decide the paint.
Are you planning to do any interior work? I need to reupholster my white vinyl front bench and in the front for sure and probably the back to it matches. Then the door panels need to match too.
Thanks for all the pics. You're doing an awesome job!
The one reason I got this car was because the interior was in great shape. Only a tear in the drivers side of the bench seat and a very slight split in the dash. Everything else is in great shape.
E15FC340-E7CA-4995-9523-9B1D879EDC9A.jpeg 7978F37C-B6C7-42F7-BDB6-3B46E77251B0.jpeg 92FE9176-9869-4A4C-85D8-D70571DD9796.jpeg
Update! Axle is completely torn down and the outer seals have been removed. Was a PITA getting that third member out of the housing. The old copper washers were all crushed and holding it on. So I took a flat bladed screwdriver and tapped around the outer housing and after awhile got it to pop off (a little pry bay effort was also required as well). Just got done cleaning all the gunk and crap out of the inside of the housing. Oh and I also stopped by my local Eastwood supplier and picked up some POR15 and rust paint. The rust paint for under the car and the POR15 for the axle! She's gonna look good when all painted up!
IMG_0268.JPG IMG_0269.JPG IMG_0270.JPG IMG_0271.JPG IMG_0272.JPG IMG_0273.JPG IMG_0274.JPG IMG_0275.JPG IMG_0276.JPG
Welp just got done the application of POR15 on my axle. Came out pretty good in the end I would say. Quite a lot of work to get it done. Tomorrow I am going to finish up under the car cleaning/sanding and painting everything else. Oh I managed to snag a brand new panhard bar as well! Adjustable and made from 4130 chrome moly steel and it has polyurethane bushings with grease fittings! I already checked and it fits perfectly! The place I also got it from offers both upper and lower control arms as well in the same adjustable setup! However these were meant for the Ford Galaxie so not sure if the control arms would work given the Galaxie was not as heavy. 3600-3800lbs vs the 4300-4500 for the Thunderbird. They are the exact same mounting/bolt locations and hardware. The only difference is the actual car itself.
EDIT: 1969 Ford Galaxie with the 429 had a base curb weight of 4200 so with that in mind they are pretty much the same if you will. I am going to order the upper and lower arms and see for myself.
IMG_0277.JPG IMG_0278.JPG IMG_0279.JPG IMG_0280.JPG IMG_0281.JPG IMG_0283.JPG IMG_0284.JPG IMG_0285.JPG IMG_0286.JPG
They came out great. What is the name of the company you got the parts from. There was a guy asking where he could get a new tracking bar. Your under carriage is going to look awesome.
