1966 tbird 390 no spark from coil
K
Oct 4, 2019
Hi
We have recently replaced the starter relay .
I think the wires were replaced correctly followed the diagram from chiltons book and it looks correct. Motor cranks over ok
But no start.
Found no spark from coil
Replaced coil still no spark
I would appreciate any ideas what to look for. Thanks
Hi
But no start.
Have checked the wire from positive of coil to I side of the starter relay
Thanks will try that in the morning
Ive been reading this could be ignition switch issue?
Car has been sitting not run for a long time like 2-3 years so i cant see how the ignition switch would have gone bad
try swapping the 2 plug on wires on top of solinoid
Plug wires on solenoid? Let’s get our descriptions correct....
There are no plug wires on any solenoid.
there are two wires on top of the relay solenoid by the battery that just plug onto it.
Yes. That is the starter solenoid, and one of those wires does run to the ignition coil.
Hi
But no start.
You ever find any luck? It’s about 3 years late but I’m having similar issues and curious on your discovery
Hi
But no start.
1} I do not trust Chilton's motor manual
2} Check and see of wires are not crossed {switch the wires and see what happens}
3} Check points and condenser
These are the easiest steps to check
4} Check your grounds
