1966 has air shocks | Ford Thunderbird club group 1955-2005 T-Bird models
1966 has air shocks
  • Thread starter Thread starter joej
J
Greetings,
I recently purchased a 1966 T-Bird as a project car. It has air shocks on the rear. I do not think this would be factory, but I am learning about this vehicle as I go. Has anyone else experience this with their T-Birds. Could be the leaf springs started flattening out because of vehicle weight. I would prefer to go back with a standard shock. Any insight would be appreciated.
Monroe or KYB should be easily available for the rears. Never any factory air shocks offered on theses cars.
air shocks were a pretty common modification in the 70's. Friends were putting them on pretty much everything.
Don't know about the flairbirds but I've seen comments from several people who used air shocks on baby birds and thought they worked fine. Don't use a t-fitting, use separate inflation lines for each shock even if you use the same pressure in each. T-fittings make handling on curves worse.
I found that air shocks are sometimes added to compensate body leaning more on one side or in your case maybe sagging rear springs. Id take them out and determine if any change in body height is acceptable to you.
Replace air shocks with standard style replacements. My 1965 rode much better with shocks I got from summitracing.com. But, still had some body roll on right turns. Installed a clamp on single additional leaf from O'Reillys on both sides and really made cornering and overall ride much better
