1965 stops running after sitting idle | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Randy S
R
I have a 65 Thunderbird that runs for awhile then suddenly stops running. After sitting awhile it does it again - Temp guage doesn't indicate an overheating conditions - what could be causing this?
Your title has been revised. Since this is a Ford Thunderbird site, you can omit the Make & Model of your car from the subject to shorten it.
Does it JUST shut off or does it feel like your running out of gas??? Gas problem, tank has dirt that collects on filter when driving, gas line has dirt, does it have a fuel filter? Electrical could be a number of issues, bad coil, loose wire or bad connection.
When engine stops, if you can do this at home in your driveway, have air cleaner off before you start inspection. After engine stalls look directly down into carburetor and press throttle with your hand. You should see 2 jet streams of gasoline that are from the accelerator pump. If no jets of gasoline are observed carburetor bowls are empty of gasoline. You are now looking for reason no fuel is getting to fuel pump.
To check If you are experiencing an electrical issue, after engine stalls remove a spark plug wire. Insert into the plug cap end an appropriate sized screw driver, don’t destroy the metal insert inside plug cap, hold screw driver by plastic handle. Hold screw driver so that the metal shaft is close to any metal of engine, 20 to 40 thousands, and have someone turn key ignition so that engine cranks. You should hear the snap of the spark, in a day light situation you may not be able to see arc. If no spark, ignition system at fault. Points closed or badly pitted, capacitor shorted, coil opening internally.
There are many visuals on U tube that explain and demonstrate these checks. You are never too old to learn something new.
Only while idling? Just as a first step check, take off your gas cap and see if that doesn't take care of the issue, the venting in the cap may be clogged. Better to start with the basics.
Can you tell by looking at the gas cap that it's clogged? Can it be cleaned or just buy a new one?
