1964 Brakes not working, firm pedal | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Guecubu
Guecubu
2
He got the car and sat on it and told me that the previous owner put new brakes in but according to him they didn't work when he was driving it (luckily avoided a bad accident) He is saying the brake pedal itself is firm and he's not getting much in terms of stopping power. Physically I pickup the car this weekend so I haven't been able to inspect them myself yet but I'm hoping to hit the ground running on trying to repair the problem and am hoping someone here might have an idea where I should start. Any thoughts?
First thoughts, check and make sure the brake booster is hooked up. If it is and the car runs rough you may have a booster internally leaking vacuum. Get the car up where you can get under it and look at the rubber brake lines. If they're old they could be an issue. They deteriorate from the inside out. Post pictures when you get it home!
I once had the same problem with my ‘64. New brakes/hard pedal/no stopping power. Cause: the plastic fitting on the Vacuum line at the Brake Booster has a “dual inlet”.
One of the inlets is supposed to have a “cap” on it. Mine was missing. Replaced it. Problem solved!
Thank you I'll definitely check that out when I see it Saturday
Some simple checks for the booster: First, make sure the one way vacuum valve is truly ONE-WAY, you can check that using your mouth on the hose, Second, with the car running shut it off and pump the brakes several times, you should still get a few boosted brake pumps via the reserve, the, Third, immediately after the second test put your foot on the brake and press while starting the car, the brake pedal should drop one inch (apporx) as the boost kicks in. Any of those fail you have a booster problem.
Finally, I've seen a lot of inexperienced people reassemble drum brakes incorrectly. Put leading/trailing shoes on wrong, replace springs improperly, jam up the self adjusters Or put them on the wrong side there are LEFT and RIGHT specific sets.
Good advice from all before me. Got my '63 with the same story from previous owner. I had the same problem back in the 60s and turned out to be a bad vacuum line from the intake to the booster. Another time it was the booster. In my current case it was a combination of problems i.e. booster, wheel brake cylinders and vacuum canister. In the end I converted the front to disc brakes with a new booster and dual master cylinder. Problem solved and much better braking for the Old Girl.
Question...my 1965 Bird is leaking between the master and the booster at the junction point where they join together. I've bleed the brakes several times and have a leak between the booster and the MC. I need to replace the power booster and stock single reservoir MC with a new Booster and Dual reservoir MC and have looked at a dozen or so You Tube Videos on it. One, does anyone have the part number for the PB and MC with all the necessary parts for the complete brake replacement for the '65 and who might you recommend to get that from? I have drums on the back and disks on the front. Second, how difficult is the proportioning valve adjustment? Last, in retrospect would you have done/changed this differently now that you look back on it? I want to get rid of the single MC.
You got me.... I thought you meant the newer technology ABS (anti-locking brakes) brakes and not a conversion kit by a vendor with that acronym... Took me a minute.
