1964 battery drain | Ford Thunderbird club group 1955-2005 T-Bird models
1964 battery drain
  • Thread starter Thread starter kentrx1
K
have a mystery battery drain that drains battery overnight. happened after engine reinstall. thought it was the alternator because if i disconnected wiring from alternator drain would stop. purchased new alternator and still get same issue. suggestions appreciated.
1964 was the first year for the alternator in the Thunderbird. The voltage regulator was not built into the alternator but instead is mounted near the radiator IIRC (if I remember correctly). Unplug it and see if the drain stops.
I would suggest a battery cut off that mounts on the negative battery post.
I would certainly unhook the battery at night. That would prevent a possible fire and verify a short.
can anyone tell me the proper wiring of the alternator and voltage regulator? what voltage (if any) should be on each color wire? thanks
