1962 dim headlights
aa010175
aa010175
Member
Oct 22, 2023
My 1962 T-Bird headlights are really dim and near yellow looking. It’s a generator car that charges normally. The light bulbs look new. Dim or bright doesn’t seem to matter. You can’t see anything with them. All the rest of the lights look normal in brightness. Thanks Dave
Your floor mounted high beam switch may be corroded. Check the connection to it also.
Check the ground to the lamps. Run a wire from a good ground to your present ground wire to see if that makes a difference.
Just checked the volts at the bulb to be 9.25.
bad wires, corroded connections, loose connections. You should have a little above or below 14 volts with the engine running.
