I want to install original style fuel filter and fuel lines from fuel pump to carburetor. This includes installing the fuel filter bracket assembly. My question is, does the bolt that holds the bracket need to be torqued to a specific spec? If so, what is that spec? Photo attached.
Also, based on further research it appears I have a replacement carb. Does this look correct and I would then need the attached fuel line?
Thank you for your help!
