1957 retro replacement engine and transmission | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Jim Christian
J
Jim Christian
1
Forgive the heresy, but for a variety of reasons, I'd consider a modern replacement engine and transmission. Not looking for more power, but more reliability and driving range (i.e. a long trip without anxiety). Any knowledge on this would be greatly appreciated. Yes, I know a RetroBird would fill the bill, but I absolutely love the 1957 cars.
Search for restomod and you will see some builds.
Kinda depends on what you want to do. If I was going this far I’d do a 5.0 Coyote and Tremec TKX 5 speed. I’d throw in an upgraded front suspension since you’ll have the motor out. Of course at this point, you need a new rear end to take full advantage of the HP upgrade with disk brakes all the way around. Or if you just want to stick with the engine/transmission, Ford 302 and Tremec T-5. I just inherited a ‘55 and plan on installing the TKX on the original Y-block. The original motors have plenty of power and the one I have was rebuilt so it’s solid. I’m also going to install a Holley Sniper 2 EFI and electronic ignition. So many ways to go with these old beauties!
If you wnt HP from the Y block it's got great potential becausr of it's strong bottom end but the heads were crap. There are companies out there that have new designed heads that fixed the problem. High compression equals high horse power.DO IT!
