1957 Pertronix | Page 3 | Ford Thunderbird club group 1955-2005 T-Bird models
1957 Pertronix
  • Thread starter Thread starter dickday0
I've always had good luck with Pertronix but things do fail from time to time. I also never really had much problems with the old points and condenser setup but I did get tired of having to readjust them. Even on my HO Pontiac 400 back in the day it wasn't the points that caused me to have to do a tune up every 6 months, it was the lead fouling on the spark plugs from the heavily leaded premium fuel.
Bumping this old post in case other readers encounter my recent Pertronix failure experience. I've used Pertronix units for many years on my various old Fords, and love them. I know nothing of the Pertronix II and III models; I've only used the "original", which replaces the points and condenser inside the distributor cap. They've been absolutely flawless... UNTIL this started happening: after a couple minutes of run time, my car would immediately stall (no stumble, no rough running, just an instant quit). I couldn't restart right away, but after :30 seconds or so, she'd fire right up and I'd have no further problems. During on one of these episodes, I checked the carburetor. Good accelerator pump squirts, so she wasn't starving for fuel, and the instant-quit indicated an ignition issue anyway. I checked grounds, connections, voltage readings, and began one-by-one switching each ignition component with spares. Voila! It was the Pertronix unit, the piece which mounts on the points-and-coil plate. A quick check with an ohmmeter showed an open circuit in the unit, as compared with two known good units, which show some resistance. I have no idea why it failed; the car is otherwise bone-stock and I'm using Pertronix' Flamethrower coil in the exact configuration they recommend. So... go figure. One of those random occurrences to remind you that even an upgrade to a more "reliable" system can still have problems.
One of the lessons I learned from this forum was to run an additional ground wire from my distributor to the block due to the poor grounding of the old distributor to the block. I believe this has saved me a lot of problems
I have used Pertronix for years on many cars. Best “drivability” improvement you can make. The 1281 doesn’t require a hotter coil.
None of them require a hotter coil, that's all marketing and extra profit. The only coil issue that needs to be checked is the coil resistance, esp for the original ignitor models. There is a minimum value, which I don't recall but the instruction sheets for the ignitors have the info.
