1957 dash | Ford Thunderbird forum club group 1955-2005 models
1957 dash
  • Thread starter Thread starter handyman
H
8
how do you remove or get behind the dash instruments to service them, under dash or does it come out from the front, don't see any screws to remove? thanks
There should be slotted screws that retain each instrument to the back side of the panel. Once removed, Then it may take some fiddling to get the instrument loose. Especially if they have been mounted for 60 some years. Taking the seat out will help getting to the underside of the dash unless you can bend your body enough.
Thanks, I suspected that was the way, I wanted to change out the oil and gen lens" may not be worth the effort.
