1956 power steering seals cylinder order & positioning
In future posts, please choose a subject that summarizes your post. ""Ram cylinder overall 1956" could mean anything. Good titles receive more responses. I will update this for you.
The power steering cylinder is easy to remove and rebuild. I purchased the rebuild kit from CASCO.
https://www.classictbird.com/Kit-Power_Steering-Cylinder-Seal-55_56-1-Per-car/productinfo/3A764A/
Since you will have the cylinder off be sure to replace the power steering cylinder bushings also.
https://www.classictbird.com/Power_...shing-Kit-55_56-1-Per-car/productinfo/3C590A/
Attached are some pictures from when I rebuilt my power steering cylinder.
Thanks for the response. When placing the seals in the cylinder I think the lip faces towards the pressure side. There are two seals one flexible, go's in first lip towards the rear of the cylinder, that a spacer then another hard seal with the lip facing towards the rear of the cylinder than brass washer and lock ring. Is this the correct positioning of the seals? Thanks
A spring-loaded lip type seal, a dust seal and a scraper are installed in the rod end of the cylinder, and are held in place by a snap ring. When installing the spring-loaded lip type seal, the lip faces towards the cylinder which is the pressure side.
Thanks Doug that is what I though. Great illustration. My 56 is currently on a rotisserie and being stripped of several pounds of undercoating. While it is up I have removed anything bolted, stripped it and overhaul/repair it.
Wayne
1956 Thunderbird
