I started removing the weather stripping from the hardtop and I found a lot of putty/soft black filler under the old weather stripping. It kept the old weather striping from pulling down tight to the mounting areas in some places. Is it correct to put this putty under the weather stripping or should it just be screwed down directly to the fiber glass or over the SS trim mounting strips. I've included some pictures of the putty as well as two of the new weather strip. I'm a little concerned about the quality of the rubber. In some places there are small holes, like air bubbles, in other areas it's clean and smooth. Am I being overly critical or is this normal.
