M
- Mar 25, 2019
- 1956
My mechanic said the mechanical fuel pump is not making contact with the cam shaft to make the fuel flow so he switched to an electric fuel pump ( EDELBROCK 1301) he placed this on the lower part of the front fender near the firewall. the problem is it has died twice and I am on the third Edelbrock 1301. The directions say to mount this near the fuel tank, but there does not seem to be any place to mount it below the gas tank. I am now looking at the Holley red but it will have to be mounted on the lower part of the front fender near the firewall. It will be below the gas tank. . He said he has mounted theEdelbrock 1301. on corvettes also on the front fender aways from the fuel tank and has had no problem with The pump the 1301 in my T bird runs for a while and then dies. Will I have better success with the Holley. the electrical connections are good so that is not an issue. Any ideas about this problem will be greatly appreciated, I am not enjoying this beautiful car I am afraid to drive it for fear of getting stuck. The next step after the Holley will be to replace the cam shaft, and also the timing chain and go back to the mechanical.fuel pump at a great expense.
