1955 radiator large spring in lower hose, | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter photoguy
photoguy
photoguy
7
Evening,
Doing lots of service on my Bird, the lower radiator hose had a large crumbled spring inside. Have never seen anything like this, any idea why someone would do this?
Correct, many vintage cars have the spring in the hose and I would replace it with the same type.
I suspect that hose has been R&R'ed before and reused and somebody twisted the snot out of it during the process - buy a new one...
Evening,
Thanks!View attachment 31680
They keep the hose from collapsing from the suction make sure you replace with one that has a spring or you may end up with over heating problems. Looks like someone tried to remove it by twisting it, bad idea
Evening,
Looks like someone has pushed a couple of cut up bed springs into the hose! As others have said, the lower radiator hose needs to have support to stop it collapsing and causing over heating issues. The specialist suppliers have replacement hoses with the appropriate coil already fitted inside.
Evening,
Actually, some molded hoses come with a "spring" inside, that keeps the hose from collapsing, especially if there are tight bends. Yours looks pretty old & corroded, which I've never seen before.
