- Sep 1, 2020
- 1955
I need to replace the left door latch in my 1955 Thunderbird. Does anyone know where I can get directions?
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Your title "I need to replace the left door latch in my 55, does anyone know where I might get directions as to how to do it!" has been revised. On future posts, please use the four-digit model year of your car along with a short summary of your post.I need to replace the left door latch in my 1955 Thunderbird. Does anyone know where I can get directions?
Window crank tool.I've never seen a step by step set of instructions, that doesn't mean they dont exist some where. I just finished doing my driver's door lock. You should have a special tool to remove the inside door handle and window crank. I believe most of the T-bird dealers sell them. It's not expensive. Yes there are other ways to get them off but this is the best way to do it. You need to remove the insde door panel. A few screws and I believe 5 snaps,3on the back 2 on the front. Use a screwdriver to locate there exact location. Use a large screwdriver and pry out right at the clip. remove access panel. roll window all the way up. remove the glass rear track. I took out my outside handle. 3 screws hold the inside door latch mech. remove the 3 screws then you can slide off from latch. Now remove the 4 screws holding the lock assy. Some also have a bolt or screw on inside. Have fun
Need to take assembly out of door, not the outside latchWhen you say door latch, do you mean the latch on the door or the striker plate on the body frame?
