WTB- 62 Seat Control Relay | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Maury
M
1
Trying to repair the electric seat (driver side only) on my 62. Have come to a much, much deeper understanding of the circuitry - after following many dead ends. I'm now thinking that the issue may reside in the seat control relay located under the seat near the seat motor. Unfortunately I've had zero luck finding a replacement through my usual parts suppliers. Any sugestions where I could find one?
Please put parts wanted in the parts wanted forum. I moved your post.
Did you clean the two little boxes that engage from the relays? That is all I had to do. My relays were fine. Didn't even have to take them apart, i just sprayed them and walla. Fixed
I think you are referring to the horizontal and vertical solenoids. I'm pretty sure they are ok. I have taken the boxes off , and I get movement if I wire power directly to them, but not if I operate the switch - which I replaced just in case. Thinking the problem is within the relay (picture attached.4448892A-D6E1-4FDA-914A-2A25A3C590D2_1_201_a.jpeg
