Tanna's57TBird
- 1
- 1957
I parked my 57 Bird about three months ago. When I went to start it recently, it would turn over, but it would not start. There was no fuel in the glass bowl so I pulled the line off going to the line from the tank, no fuel. I made sure there was gas, there was.
I decided to change out the fuel pump, the the new pump reacted the same as the old one, no fuel. After some work was able to get fuel up to the bowl and then to the carb.
Then, there was no spark, so I jumped the car and it fired, but would only stay running as long as you shot it with SFluid and or once it was running throttle it up to 4k rpm. As soon as you backed off the engine would not idle. Its acting like there is not enough vacuum to pull fuel into the intake manifold from the carb.
Can't figure this out, should be so simple, it runs but will not idle. Another issue is after it sits a few hours, the fuel in the bowl goes somewhere most likely back to the tank.
Any ideas?
Any ideas?
