Starter 56 Tbird. | Ford Thunderbird forum club group 1955-2005 models
Starter 56 Tbird.
  • Thread starter Thread starter Keith V
Keith V
I installed a new battery. When the positive cable was installed, the starter engaged and turned over the motor even though the ignition was off and the transmission was in park. Any ideas why that would happen?
It sounds like you have a solenoid issue as well.
Perhaps the solenoid. Could also be the ignition switch. I would check continuity. I don't know that it would solve anything but, If you connected the plus side first I don't think it would happen instantly since it would not be grounded. My way is to install the positive first and the negative second. I find I have less of a spark issue in that manner. good luck, J.
The solenoids contacts have been noted to stick closed. I recently bought a solenoid that was stuck brand new. Hopefully you didn't remove the wires and replace them in-correctly. Hope this will help
M.L.
I agree with odlewis, with the transmission in park you can rule out the ignition switch.. I carry a spare starter solenoid in my trunk, just in case.
