- 1,131
- 1955
My 1955 Thunderbird, with a Fordomatic transmission, had the carburetor rebuilt in the spring and it has been running without any problems until lately. The problem I have noticed is when I accelerate under light to moderate throttle, it will almost feel like the engine is puttering or holding back. If I accelerate from a stop there is no hesitation and the engine idles smoothly. Since it seemed like my problem was with the spark advance I checked the timing to make sure it was set at 6 degrees, but when I accelerated the engine there was no advance. I made sure the breaker plate was moving freely when I applied vacuum to the advance using a hand vacuum pump. If you put hand on the vacuum line at the distributor you can feel very slight vacuum, however when I put a vacuum gauge on the line there is not enough vacuum to obtain a reading on my gauge at idle or under acceleration. If you look into the small vent holes of the spark valve mounted on the carburetor, you can see the spark valve diaphragm moving under acceleration. Since I had an extra spark valve I put it on the carburetor, however the results were the same. The questions I have for the group is what is the vacuum reading at the distributor advance supposed to be at idle and when accelerating? Also can someone explain how the spark advance circuit of the Holley 4000 carburetor works?
Doug
Doug
