B
- Dec 29, 2017
I replaced my Intake and Carb on my 1955 TBird. I used a later model Intake Manifold and a Holley Slayer Series Carb. with 450 CFM. With the original 292 Y Block intake and the Tea Pot carb, I had a HEI distributor running. There was no problems with this setup. However after replacing the Intake and Carb to the newer setup, There appears to be a Spark Advanced problem. Previous Vacuum to the Distributor was taken from the Intake Manifold. With the New Holley carb, the vacuum to the distributor is taken from the Vacuum Chamber inside the carb.
When driving I get a backfire type noise through the carb. This is what leads me to the timing advance on the distributor.
Should I be using the Manifold Vacuum or use the Vacuum from the Carb?
