J
juiced99ws6
- 0
- 1964
So I drove my 1964 Thunderbird home about 400 miles and was under the impression from a friend that before I left on my trip home all my lights worked fine. First day I drove it to work after that I was informed my brake lights didn't work. When I got home I took a look and realized that they are just stuck on all the time.
If key is turned to the run position my brake lights come on and will not go off. I unplugged the pressure switch from the master cylinder and they stayed on. I then jumpered the wiring since I did on know if the switch was normally opened, or closed. Lights stayed on. If I turn on my signal the lights will blink between dim and bright like they should if brakes were applied and the turn signal was on.
If key is off and I turn the headlights on, all the lights work and the taillights are dim. as soon as I turn the key back on then the taillights light up bright again.
I really do not know where to go from here so any help is appreciated.
