TheRareBird
- 0
- 1967
I had no luck looking a Back Window for a 1967 4door used or otherwise without it costing thousands.
Does the 2Door back glass have the same part number and the 4door? There are a ton of 2 door back glass out there.
Found this says it is the same but this was from a eBay motors. Don't know if I should trust it.
Compatible with.
Thanks
DG
Compatible with.
1968 | Ford | Thunderbird | Base Sedan 4-Door | 7.0L 7030CC 429Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base | 6.4L 6391CC 390Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base | 7.0L 6997CC 427Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base | 7.0L 7014CC 428Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Hardtop 2-Door | 6.4L 6391CC 390Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Hardtop 2-Door | 7.0L 6997CC 427Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Hardtop 2-Door | 7.0L 7014CC 428Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Sedan 4-Door | 6.4L 6391CC 390Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Sedan 4-Door | 7.0L 6997CC 427Cu. In. V8 GAS OHV Naturally Aspirated | |
1967 | Ford | Thunderbird | Base Sedan 4-Door | 7.0L 7014CC 428Cu. In. V8 GAS OHV Naturally Aspirated |
DG
