Thanks for all the info. my engine is a 428 SCJ block with mid 60's 390 heads and an intake off of a 63 427 low riser as in a Galaxie. I downloaded the
repair manual this morning and there was no location given as to the whereabouts of the relay. I will find it, I did Google 59 Thunderbird and looked at the images but all there was were images of the 55-57's. The manual did contain some good troubleshooting and images of the
parts but no real locations. No AC wish it did! I was lucky in that I was able to locate a T89 w/R11 overdrive so it is the heavy duty model used behind the FE's in the 60's. This past weekend I purchased another T89 but this one is a truck version with the shorter tail shaft and the yoke bolted to the output shaft. All is good, I've got a number of spare
parts now so I hope to get everything bolted up by the first of the year. My car is an original 3 speed manual car that has been converted to a 5 speed T5 with a G-Force heavy duty upgrade. Everyone thinks I'm nuts for wanting to take the 5 speed out but 3 on the tree with OD will be different.
