B
BigBird
UPDATE EMAIL ADDRESS
My '96 LX (dubbed the "Great White") is terrific, fun to own and drive. But like all things (me included) it sometimes needs repair.
The passenger side window won't run up & down and you've got to pull or push it. The motor makes a "ratchet" sound that's very vigorous and fast, so I'm guessing that the motor is probably okay but the window has jumped its tracks.
Of course the motor or mechanism may need replacing but who knows?
Yes I can take it to a good nearby shop and pay about $300 but I'm trying to save some bucks.
And no, I'm not physically able to work on the car myself, as I'm partially disabled, even though yes, I do understand tools and can understand instructions - I just can't physically do the work.
Here's my question: How hard is it to remove & re-install the inside of the passenger door? Does it require special tools or can any reasonably competent person remove it and properly re-install it with regular hand tools (screwdriver, socket wrench, etc)?
Thing is, a pal of ours says he can remove the inner passenger door panel and check the window mechanism and even fix it. Now my car is parked in a nice private off-street space w. overhead shade, so it's not gonna be worked on while dodging traffic or something. Easy access, no problem there.
All I'd really like to know is:
1) Is removing and re-installing the inner door panel a big chore?
2) Can this job be done with regular hand tools or does it require specialized automotive tools that only a shop would have?
And 3) if possible, can someone post me the method and technique for doing this task, or guide me to a link with the necessary instructions?
In other words, am I asking for trouble if this pal "shade trees" the repair. I don't want him to get the door off and break something or not be able to put it back on, obviously.
So I'm asking about the difficulty of this job. Also, although I'm hampered by severe arthritis which precludes me from physically doing the work, I'm quite competent with tool knowledge and know all the lingo -- my arms and hands just can't wield tools that well any more.
Thanks in advance!
Thanks in advance!
