62 Steering Pivot Bracket Bush Supplier? | Ford Thunderbird forum club group 1955-2005 models
Hadderz
Hadderz
59
Hi anyone know of a supplier who has the pivot bracket bush? This is the rubber bush that sits on the clamp which connects the column to the steering gearbox that has the dowel pin connection. The bush is sort of cotton reel shape (flared top and bottom) and has a nylon plastic T shop washer pushed in top and bottom.
Thanks in advance!
Hi there. My favorite go to places are Thunderbird Headquarters and Bird Nest. The former sells used parts as well, I believe. You can then google the part and find additional sources I would think. Good luck!
Doug
Doug
Thanks, tried those but seems the parts haven’t been reproduced. Not sure if I want used but may have to go that route.
Hadderz,
Resurrecting this old thread to see if you ever found a replacement bushing? Or if anyone else can recommend a source for a new part?
I just discovered that my pivot bracket bushing is gone and I need a replacement.
Thanks in advance!
Hadderz,
Thanks in advance!
Hi Nope, nothing found!
