For anyone still keeping track - with matching rear wheel cylinders and the retracting springs mounted correctly it still pulls. Not "jerk the wheel out of you hand"/"change lanes" pull like when this started, so there was some progress.
Panic stop from 15 mph both right wheels lock up, nether left wheel does. I've bled the brakes like crazy - no air.
I bought the car over the summer, so it's new to me. The prior owner had RR wheel cylinder replaced in May. He did not change shoes, did not change or rebuild LR cylinder...
The brakes did not pull when I bought the car, or if they did it was so mild I did not notice. So it was fine for the first couple hundred miles.
It did have an issue with vibration above 55 mph which the prior owner disclosed before sale. I had the 30+ year old tires & tubes, and one K-H
wire wheel replaced to address the vibration issue. I checked the brakes while the wheels were off and found the RR shoes and drum surface felt oily. Cleaned with Brake cleaner, reassembled. Adjusted brakes on all 4 wheels. This is about when the trouble started.... didn't notice anything right away, but shortly thereafter I had to make a panic deceleration because someone changed lanes in front on me and then slowed quickly to make a right turn. My car changed lanes to the right all by itself! From that point on the car pulled strongly to the right when braking but no issues when accelerating, cruising, or coasting.
the work so far:
- all 4 flexible brake lines replaced. line to rear axle was likely from 1957.
- front wheel cylinders rebuilt (LF has a little weeping under the dust boot towards the primary shoe) - there was no pitting in the bore and I had rebuild kits on hand
- retaining pins on LF brakes shoes bent over like arthritic fingers - replaced both
- replaced all 4 rear brake shoes in case RR was damaged by the prior leaking of the wheel cylinder
- replaced both rear wheel cylinders so they match, corrected retaining spring attachment, bled rear brakes
- replaced upper and lower control arm bushings as they also appeared to be 63 years old and cracked/dry rotted
- replaced sway bar bushings
- Mechanic says eveyting else in the front suspension is good
- Wheel alignment
- moved wheels around to different location on car
One other odd thing likely not related - even with the 4 brand new American Classic 'bias look' radial tires, if the road surface is the grooved concrete the front tires want to follow the grooves like bias ply tires.
Ever see anything like this?
