- Sep 16, 2016
- 1955
I recently had my 55 “wet” blasted while on a rotisserie. Actually much of the car was dry blasted save for the external sheetmetal. Prior to this I spent hours scraping off the undercoating softened with a product called “Been-e-do”, a solvent derived from soybeans which worked exceptionally well.
Now that I’ve gotten all the gunk out of all the nooks and crannies and have epoxy primed everything, I’m wondering how best to protect/seal that poorly designed cavity created where the front fenders overlaps the door posts? This unprotected void collects road grime and moisture which has caused the deterioration of the fenders and doorposts. I’m sure is a common problem on these cars.
It seems that some form of inner fender might have been helpful avoiding this problem in the original design.
Beyond undercoating, I’m wondering if anyone has some creative solutions for blocking or filling this void; weatherstripping, blow foam or some form of deflector?
Like many “restored “ cars, mine will lead a charmed life and likely not be exposed to the corrosive elements, but I would like to know that I’ll not have to worry about rust creeping into this area again.
Thoughts, suggestions?
Thanks
Thanks
