2005 wire wheels need inner tubes | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter robingudgel
robingudgel
4
I have (repaired) two of my wire wheels. All four tires still leak. I would like to have inner tubes added. The tire store says they don’t make inner tubes for P235/50 17” wheels. I have not found any. I did find P235/60 17” tubes. Will they work? Or is there a better solution.
Hi Robin,
In general, wire wheels should have inner tubes for reliable air retention. We used tubes in our race tires on wire wheels on our vintage racers. The main thing on installation is to make sure there are no folds or creases in the tube when inside the tire. Those create potential future leaks as they will wear at the crease. That said, it seems your 235/60-17 tubes are very close in size but a tiny bit 'taller' than what would be perfect. Check the revolutions/mile of your tire vs a 60 series tire. If they're close, there shouldn't be a problem. (go to Tire Rack and bring up your tire and check the Specs. They'll usually give you the rev/mile in the specs. Then check the same brand in the 60 series.)
I don't see that anything catastrophic should happen with that tube size, but maybe you'll want to try one wheel first and see how that works out. Make sure your spare is inflated before this test!!!
Best wishes,
Tom
I took a quick look at the diameters of the 50 series and 60 series tires along with revolutions/mile at Tire Rack for a Firestone tire as an example:
235/50-17
Diameter = 26.3"
Revs/Mile = 792
235/60-17
Diameter = 28.1"
Revs/Mile = 741
So, the taller tire profile tube might be a bit crowded inside the 50 series tire. That could lead to the type of folding or unhappy creasing of the tube upon installation. It would be better to find the proper tube, but your installer can coach you on that. A suggestion would be to spray the exterior of the tube and the interior of the tire with silicone spray. Then add a bit of air to the tube and move it around until you're pretty sure there are no folds or wrinkles in it. It's also important to get the fill valve accurately aligned with the wheel's hole without stress on the tube.
This is an interesting problem in today's "tubeless" world! Proceed with Caution!
Best wishes,
Tom
PS: Post a pic of your Bird with the Wire Wheels when you get a chance! Thanks!
235/50-17
Diameter = 26.3"
Revs/Mile = 792
235/60-17
Diameter = 28.1"
Revs/Mile = 741
Best wishes,
Tom
It isn’t looking good to find a tire shop willing to put tubes in these tires. Four sources say it just won’t be satisfactory. Be aware of this when picking tire sizes.
Those Wire Wheels look great on the Bird! I hope you can resolve the Inner Tube Dilemma!
I've looked all over the internet and not found the "right" size tube. Sorry!
Best wishes,
Tom
Here's our 1955 XK 140 Jaguar Race/Rally car on Dayton 72 Spoke Wire Wheels. We drove it in three Panamericana races (2000 miles each of Mexican 2-Lane roads - 1991, '92 and '94) on wire wheels, radial tires and inner tubes. So, it can be done. We were clocked by the Federal Highway Patrol at 142 miles/hour during one of the speed sections in northern Mexico. Not bad for a 36 year old 6 cylinder!!! That section of roadway was "interstate-like" 4 lane divided highway, standing start, flying finish over about 12 miles. We averaged for the section 111 MPH!
We also raced this car on closed tracks like Road America and Sebring. Again, all on wires with tubes. They're great when installed correctly.
Here it is in this recent photo:
Best wishes,
Tom
Yah, if the tires are the right size to match the inner tube size, it is not a problem. I had 13 57 birds all at once and 10 of them had wire wheels. No inner tubes. My new tires are just 50mm in height. If they were 60, I would not have an issue.
The black car has been a five year project. We took a basket case bird and will be powering it with batteries my company designed. The car after spending hundreds of thousands on it is in show room condition. It never should have been restored, but I just couldn’t scrap it. There can be 44 individual 1.2kwh battery modules plugged in. Many more in the trunk.
