- 14
- 2005
I was beginning to have intermittent problems with the shifter not wanting to come out of Park. I saw a post with the same problem indicating it was the brake switch. I confirmed that the brake lights were not coming on when the shifter stuck. I bought the replacement switch and pulled out the old one. The plunger on the new switch was about 3/8 inch longer than the old one making me think the part did not match. I talked to a Ford service tech who told me to install the new switch and the plunger would ratchet in to the right length as the brake pedal was operated. Sure enough he was right.
Tips on replacement: Remove the plug from the back of the old switch. Turn the switch about 1/4 turn clockwise to remove. You will have to depress the brake pedal when you install the new switch since the plunger is too long. Release the brake pedal and it will push the plunger into the switch to the proper length. Operate the pedal a few times to seat the plunger to the proper length. Don't pull on the pedal toward you as that would push the plunger in too far. Replace the plug to the back of the switch and test the operation of the lights and shifter.
It's a simple fix but that longer plunger had me scratching my head for a while.
