2004 new radio no power after installation | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter gnilier
gnilier
1
Hello, I have a 2004 tbird and while putting in my aftermarket radio(Sony XAV-AX3200), the car was running and the radio was on and playing. while placing it back into the dash, the radio just cut off. I have removed it and redid all the connections. I even connected it straight to the battery correctly and it turned on. I have replaced the 3 fuses I could find for the radio,(passenger compartment fuses, #2, 5A Radio Start signal, #18 20A radio, central imaging amplifier, #27 10a radio, Trunk compartment fuse #18, 20a, subwoofer amplifier). Still no power. Any sugestions would be helpful. I even tryed putting back the original factory radio and nothing.
You need to test for power at your fuses.
Pull the connector from the radio and turn the key to ON position. Probe the 12v supply pin to chassis. Probe the "on" pin (forgot the name, it's the signal to the radio that ignition is on). If either of them isn't 12v, that's your issue. Then probe them each to the ground pin on the connector. If either dosen't show 12v, then both should not be 12v because your ground wire is the culprit. Theres just as much chance you broke your ground wire connection, as the chance that a fuse blew or you broke a 12v connection.
Better not to insert the radio while car is running or key is on. Better to disconnect battery after you confirm everything works. Then reconnect after installing radio.
Good.luck!
