2004 Hard Top Installation Tips | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter bobspeed
bobspeed
I’m having trouble getting the hardtop to my 2004 T bird to sit and see correctly. Has anybody else had this problem?
I just bought this car and have no idea how to take the hard on and off, does anyone know of a good video online that would guide me through it? Or written instructions with pics? Thanks for any suggestions!
Since you obviously didn't receive an owner's manual when you purchased the car, here are the hardtop removal and installation instructions from the owner's manual.
Hi all, just bought a 2004 TBird, and having a heck of a time trying to get the drivers side torx screw to engage. No issues on the passenger side. Not sure if the screw is striped or if the top just isn't coming close enough to engage.
Just curious - how large is the gap between the window mounting and the hardtop before trying to engage the screw?
Thanks!
Scott
Sounds like you are not lined up properly. Distance between screw and hole should be close unless the screw is blocking the space between the frame & top !
Best advice is to not tighten any of the other three mounting points until all are in place. When my 2004 left windshield screw has this issue, I undo the right to then start the left with some strong arm alignment; it will go, just tighten a bit at a time. Sometimes an alignment guide like a small phillips screwdriver has helped. GoodLuck!
