2003 Smokes when hard acceleration | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter dlm007
D
dlm007
I have a 2003 t-bird and have noticed that when I accelerate hard, light blue smoke comes out of my exhaust. I also noticed that when I start the car after sitting for a couple days, a puff of blue smoke comes out when I start the car. I took it into the dealer and they said there was bulletin on the valve cover gaskets leaking. They installed the fix and it still smokes occasionally on startup and smokes a lot when I accelerate hard.
I would think this is a problem with myexhasut value guide leaking?
Thought??
There's been a few that reported the same thing. Not burning oil or anything. Most were told to forget it.
have you had the computer read for codes? my pickup does that some since the "check engine" eluminated. i had already spent over 200.00 trying to get that light to go out and stay out, so when the shop said another 200.00 should do it, i said forget it. the mix can be made richer or leaner on a misread computer issue, and thats the explanation i got for the pickup. mine only smokes on startup then stops. but i did have a computer alert. but i changed 2 items that were supposed to fix it, no luck. it doesn't effect performance or mileage on my truck.
Found this info, it may help:
"I have a 2004 Tbird and when the auto is first started a puff of blue smoke rolls out of the exhaust. I took it to the Ford garage and they want to say that it is the metal in the exhaust system that is causing it to smoke. It is so bad at times it is embarrassing. I have seen other Tbirds start up without smoke. I have checked the oil levels and they seem to be fine. The auto only has 12,000 miles on it and has always had the oil changed at the dealership. Is this typical? Can it be the metal in the exhaust. Ford refuses to do anything about it."
Another:
"My car did this twice in a few day period in the 3 years and 4 months I've owned it. I mentioned it to the dealer, they could not find anything wrong with it. It hasn't happened for over 2 years now, so I figure it was an anomaly."
And another:
"Our 02 did it one time in Amarillo when we were at our sponsoring dealer for a monthly Thunderbird meeting. It was embarassing in front of about 20 other T-Birders. The car had about 4,000 miles on it at the time and never did it again. It now has 7,000 miles."
