- May 29, 2018
- 2002
Tried to start the bird this morning. Battery is dead, no electricity at all. So....how do I open the trunk to charge the battery if the unlock has no juice to open it?
HELP!
HELP!
Please
sign in or
join the Thunderbird
If you forgot your password
click here
Everyone should periodically check the operation of that method for opening the trunk. The key operates a cable that has become detached in some cars. If that happens, you can access the trunk by removing the panels behind the seats. Another option is to charge via the cigarette lighter.To get into the Trunk with a dead battery there is a key slot in back of the Drivers seat on the back wall, Put your ignition key in it and turn. Your Trunk will pot open.
Key won't turn, or the trunk does not open when you try to turn the key? If the latter, try having someone pull up on the trunk lid while you turn the key. I had this problem, and it worked for me.Cannot open trunk of 2003 Thunderbird.. New battery completely dead. key will not turn in lock behind seat.
Any suggestions?
]Cannot open trunk of 2003 Thunderbird.. New battery completely dead. key will not turn in lock behind seat.
Any suggestions?
If all else fails a good mobile locksmith can cut a key for it blanks are cheap .Recently purchased tbird with dead battery. Key does not fit the trunk unlock key socket behind the drivers seat. How can the trunk be opened in this situation
