M
missinglinc
- 9
- 1989
I bought this 1997 Bird in July of 2023 as a non runner, determined the PCM to be bad, also replaced the fuel pump, plugs, wires, and both coil packs.
It has been running since then, been my very reliable daily driver, but still has some issues, namely idling fast, and poor acceleration. When I cold start it, it will fire up immediately and runs at about 1100-1200 rpm, in park, and about 950 -1000 rpm in gear, this does not seem to change until after 20 minutes or more of driving, (my commute to work is seldom longer than 10 minutes). The other concern I have is that it seems like it doesn't want to rev past about 3800 rpm in first gear when I floor the accelerator, it's as is if it has a rev limiter, yet in second gear it will pull hard, no problem. This seems to be an intermittent issue as sometimes it will pull to redline in first gear without issue. It also seems a bit sluggish when I hit the throttle hard from a stop, it seldom will spin the tires, just kind of bogs until 2000 rpm, then it starts to pick up and pull harder.
One other issue I have experienced in the past after a long run on the highway, (2 to 3 hours or more) was a rough idle and stink of raw fuel, I thought the first time that I may have gotten some bad fuel on my trip, but it happened again after running the tank to near empty. This has not happened recently, however I have not taken it on any highway trips for a while. The car has about 125,000 miles on it presently and as mentioned is my daily driver, I also have a 1989 Thunderbird Super Coupe, recently inherited, with about 65,000 miles, and have previously owned several 83 to 88 Thunderbirds and Cougars, and a 92, 93, and 94 Thunderbirds.
