- 28
- 1994
Recently, my car will not idle when I first start it. Sometimes will stumble, and than idle roughly, most times will die. Step on the gas pedal to stop the rough idle, and it dies. I can override the problem with the two-foot gas/brake method, bring the rpm up to throttle body opening, put it in gear and away I go. After a minute or two, it will idle when stopping at a light or similar.
My bible-size maintenance manual says the idle is controlled by the IAC, idle air control valve. Got a new one of those, put it in and no change. More reading, the power control module controls all the fuel functions, idle, acceleration, etc.,. Read up and tried the PCM reset options. Before I go and find a new/repaired PCM, I am wondering if that is the problem. Other than the starting problem, the rest of the car works well, Acceleration, gear-shifing etc. I do have an older-style OBD reader, but it shows no codes. It seems as though one of the inputs to the PCM needs to "warm up" or stabilize to enable the idle function. When the engine is warmed up, it idles smoothely, and accelerates smoothly, so I am pretty sure it is not a fuel delivery or injector problem.
FYI: I may have caused the problem inadvertently: I had the battery disconnected for 3 or 4 hours when I had the dash out, to replace the small gears in the odometer. Found out later, that when the battery is disconnected for a long period of time, many of the electronic modules, including the PCM lose the stored information, and have to "re-learn" inputs when the battery is re-connected. As i said, I have tried 2 or 3 times to do the recommended reset but didn't help.
