1966 Transmission leak | Ford Thunderbird club group 1955-2005 T-Bird models
M
7
I have a Tranny leak on my newly purchased 66 Thunderbird. I was going to change the gasket but noticed the lip is bent also. Anyone have an opinion on the subject? It's the Cruise-o-matic Tranny. Thanks.
Put the model year in the subject on future posts. I added for you.
It looks like the bent lip on the transmission pan could have been caused by an improperly placed transmission jack or some other support fixture. Looking a little closer at your picture I believe the transmission leak is originating from the manual shaft/throttle shaft seals and not from the pan gasket. Either way the transmission pan will have to be removed to replace the manual shaft/throttle shaft seals.
Thanks for the input. It's hard to tell with all the crud under there. I'm cleaning it out little by little. Thanks again.
This is helpful im having the same issue.
