1966 power windows not working | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Nonobrest
N
HI everyone, New on the forum, I'm writting from France. I just got a sapphire blue Tbird from Canada.
I have a problem with my main windows that both stopped working lately. The quarter windows are working. The fuses are OK, the switches seems to be good. I don't think both motors are down.
I'd like to find the windows relay, which seems to be on the firewall but I didn't find it. Could someone send me a picture of it and its position please? Could you help me to find the problem.
Thanks a lot for yours answers.
Best regards.
Arnaud
Hello everyone
I found this relay, which is in the middle of the firewall on 66. Can you confirm me that I can Bypass it to test it by joining the red wire to the black one? Thanks a lot
Best regards.
Arnaud
Arnaud, join the fun of owing a bird of yesteryear, this may or may not help, I have a 66 conv. Windows work good then it sat unused for a week or so then no windows working, with ignition off an on a hunch I sprayed contact cleaner into console switch while working switches back and forth then turned the ignition on and repeated the spraying again, all windows are operating better then ever, give it a try these switch contacts get a film on them especially if not used often good luck
Salut, merci pour ta réponse. Je l'ai fait mais ça n'a pas marché. J'ai testé les interrupteurs et ils sont bons.
Je vais essayer de contourner le relais de sécurité pour voir si cela fonctionne.
Have a nice day
