Joe32
- Jun 16, 2019
- 1965
This is not a new question but I couldn't search my way to an answer. What is the correct whitewall width on a 1965? Where would I buy them?
A few years ago, trying to save money, I bought a set of the Milestar white walls, which were awful. The first problem was the "brown wall" problem. This is not coming from the surface of the tire, but it's the result of rubber oils leaching into the white wall from behind, making it almost impossible to clean. It does not get better over time, as I've had mine 3 years. After a lot of experimenting and scrubbing, it seems oven cleaner did the best job -- but still only got them to an dull off-white color. Still you have to consider if it takes oven cleaner to get these oils off, what is it doing to the rest of the rubber?
A second problem was handling. After 2 years of attempted alignment and steering repairs, I discovered these tires just could not handle the weight and demands of my 1965 Thunderbird. It was all over the road.
Once again, I need to learn you get what you pay for.
