I have a couple of questions about the compressor. How do I determine what make of compressor is on car (photo attached).
Next questions does it matter what make of compressor I use to replace the current one and are the clutches interchangeable
This site contains affiliate links for which I may
be compensated. As an eBay Partner, and Amazon Associate I may be compensated if you make a
purchase at no cost to you.
york compressor you can purchase from about any parts store. clutch is sold seperately. you can swap over to a sanden style, but you would need different brackets
So can you use any later type compressor with the old components? Obviously using the new gas type but I'm presuming mine has dried out being off the road many years so thought replacing it with something off another vehicle.
