1965 runs when switched off | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter 22350
2
Just bought this car and it has had tons of work done to it. It has been running normally, but today I came home and turning off ignition didn't turn off the car.
I changed the starter relay and no difference.
The car has electronic ignition and was working fine. Now the brown wire to the coil is continuously hot
Any ideas?
Just now the key started working. I pulled the bottom panel and found what I thought might be a relay for the power to the coil (picture). I disturbed the wires and now the ignition turns off.
BUT....., the parking switch is not working. In the service receipts, I can see that they have been endlessly fooling around with adjusting the linkage and replacing the switch. Before, I would have to shove the steering column to the left, with force, to engage the starter safety switch....... now nothing
I see poorly crimped terminals, questionable use of electrical tape and no doubt other issues.....I think you need to get a schematic and start tracing down and correcting problems as a first step. For instance, you may find a surprise under that electrical tape alone. And your running on issue could be an ignition switch intermittent issue.
Also looks like somebody put a Pertronix ignition conversion in your distributor if you didn't already know....those require a matching ignition coil and specific wiring vis a vis the ballast resistor. Early versions of the Pertronix (Ignitor I versions) had limited circuit protection so be careful working with the ignition, disconnect the battery when doing anything suspect.
Sounds like a good path. A major concern is the neutral safety switch. I know that it was replaced, but the key is no longer working
Is that circled component stock or a relay for the electronic ignition ?
The Pertronix doesn't require any sort of relay, so I'm not sure what is going on with that item.
