I have a 1965 all original...My parking brake only releases when I pull the lever next to foot pedal. Brake does not release as it should when I put car in gear. Any one experience this
[/there is a junction block on lower
part of steering column under the dash that should have two vacuum lines attached. one comes from the right side of dash and the other attaches to a vacuum actuator above the ebrake pedal. hard to see and harder to get at. you can reach up there and feel where the hose connects. if hose is not there, you will need a pair of looong needle nose pliers to attach hose. hope this helps and good luck
