- Feb 24, 2021
- 1965
I have a new to me 1965 Bird. Heater won't heat. I don't think it's a vacuum problem, because the air will come out of the appropriate location (DEF, Floor, etc.) if that control is changed.
The Temperature setting lever is very loose (as far as left to right movement), as if it's not connected to anything at all. I removed the side of the console, to check out the controller.
The cylinder (red arrow) will move in and out when temp slide is moved, but does not manipulate the flat metal piece it goes through, as I believe it should (yellow arrow). The engine was off when looking at this.
For those familiar with the parts, is there a clip or something missing? Am I barking up the wrong tree?
I guess a vacuum leak may be the culprit otherwise?
