projo198
- 10
- 1965
Now that I have the car running nicely I have moved into the interior. I currently have the dash pulled and am trying to figure out why I am not getting any power inside the cabin. No dash lights, no interior lights, nothing. [UPDATE - The horn does still work].
I have started with the ignition. The car will not start with the key, though turning the key off shuts the car off. The PO installed a button switch which does start the car. It is very rudimentary; one side of it goes to the positive terminal on the starter solenoid and the other to the bottom smaller terminal on the same solenoid (these are the black and white wires below). But this DOES start the car.
I tried messing with the exiting solenoid, cleaned up the terminals and put it back together in what I believe is the original configuration. Still nothing, so I went ahead and replaced it. This is the old one before swapping it out.
https://i.*********/yBUi1gKl.jpg
I suspected the neutral safety switch, so to rule that out I removed it and bypassed it with jumper wires.
https://i.*********/cP9cpxCl.jpg
One last pic, there is nothing hooked up to the square tab of my ignition switch, and I don't see any lose wires. Should something be here? The schematic I am using says it is for an engine warning light. I did pull the terminal from the ignition switch and volt tested every point, there was no voltage on any of them. Should there be a constant hot there? I just finished replacing this with a new one as well.
https://i.*********/vvhXOxAl.jpg
Lastly I checked the main ground and wire wheeled every contact point to bare metal including at the battery, on the block and n the chassis just below the vacuum canister. Then I replaced every glass fuse.
Thanks in advance for your advice, I don't want to keep throwing money and parts at it to try and fix it.
