1964 radio continuous 12 volt source
Y
Jun 20, 2022
I am trying to upgrade the radio in my 1964 Thunderbird convertible. The new stereo requires a continuous 12v wire. What is the easiest way to add one? Is there a way to wire it from the fuse box?
Thanks in advance!
Thanks in advance!
Any circuit that has constant voltage other than running a wire to the battery, I would think the brake light circuit is always hot. The radio memory circuit will pull no more current than an electric clock and maybe less.
Did you pull the wire from the fuse that goes to the lighter or did you split it off from the lighter itself?
I wired it directly to the lighter, it’s a constant source of power.
Thanks. Are you able to send me a picture of the connection to the lighter? Also which wire/circuit did you use for the 12v accessory connection?
TIA
Wire it to the ignition hot switch.
