1964 No oil to left side when applying brakes | Ford Thunderbird club group 1955-2005 T-Bird models
6
Hi I have a 64a that I have replaced the brake servo on. I have measured the rod with a measuring instrument. I step on the pedal to the floor and no oil to the left front wheel but to the right front wheel. I get no pressure when pumping. Someone says it is the rubber line or the master cylinder??
How is anyone supposed to know what your post is about when you title it "1964" ?
Please title your posts moving forward. I have updated it.
possibly master cylinder rear seal failed and leaked fluid into power booster. Both need to be replaced. Be sure to closely examine rubber hose mentioned above for possible failure, and replace.
