- Aug 18, 2018
- 1964
Hi all. I have a '64 but this may apply to other years using the cruise-o-matic transmission.
My transmission was shifting fine but the kick down was not working. Also, the shift points were at set speeds, in other words pressing on the gas would not result in the car staying in a gear longer before shifting to the next higher gear. Long story short, I followed the procedure in the shop manual and set the accelerator pedal height to 4 3/8", and then set the downshift lever rod clearance to 1 1/4". The car now downshifts and stays in gear longer when under load.
Kick down is important of course but there are diminishing returns as the motor revs faster. Stock 390s develop max torque around 3000 rpm and it falls off quickly after that, so depending on the speed of the car, it would be much better power wise to just stay in 3rd gear with the secondaries open than to downshift into second for not much benefit. I'll play a little bit with the downshift lever rod clearance to try to dial this in a bit better. Observations and ideas on this would be much appreciated.
Also, I understand that at speeds over 25mph, if you shift the selector into first gear position, then the car will stay in second gear until speeds slows below 25mph.
